2006-11-24 1:53 AM
programming socket board for STR711FR2H6 available?
2006-11-15 2:02 PM
Is the programming socket board for STR711FR2H6(BGA 64) available?
2006-11-20 3:18 PM
or if I want to make a programming socket board myself,
is the AN1775, STR71X HARDWARE DEVELOPMENT GETTING STARTED , the file I should refer to for H/W pin connection?2006-11-20 10:45 PM
I can offer you the following one:
DIL48/LFBGA64 ZIF STR71x, consists of 2 pieces: BGA-TOP-84, ord. no. 70-0532 (more info at ) and BGA-BOTTOM-46, ord. no. 70-0531 (more info at ) Certainly, it works only with our universal device programmers that support STR71x devices (Beeprog, BeeHive).2006-11-24 1:53 AM
The STR71x Hardware getting started A.N describes the minimum hardware resources required to develop an STR71x application independently of any package type.
Please have a look into the STR71x datasheet and you will find the STR711 BGA Ball Connections.
