2007-08-17 2:23 AM
2007-08-16 10:26 PM
I have a reset vector problem. Once every x times we can not launch the software and when we do the difference between the code in flash and the real code, only the data at the reset vector is changed (some bits are changed from 1 to 0). How is it possible? - Our software is in flash (bank0) Thanks2007-08-17 2:23 AM
gcc V 3.3.2
as 2.14 ld 2.14 sous RIDE boot from flash memory and vector table placed at address 0x0
