M95M01-A125 EEPROM data corruption by power cut off
SHiroshi19
Dear Sir
We use M95M01-DWDW3TP/K EEPROM in device to store log data
If power is cut off during its write cycle,  the data in writing address will become corrupted as I known.
In other hand, will other data, which was successfully written in other address, become correpted?
What I am concerned about is the impact to other existing data, when power cut off in the data writing process
For an expample, there are "address A" (successfully written) , "address B" (will written log data in it), "address C".(successfully written) .
If power was cut off when writing data into address B, is the content in address A and C corrupted too or not?
Waiting for your reply
No.
But that doesn't account for misbehaviour of your software if you let it access the memory during a power failure...
So your system design should ensure that this can never happen:
  • Have power-fail/brown-out detection;
  • Ensure sufficient backup capacity to complete any ongoing memory access;
  • Block memory access once done;
  • etc, etc, ...
Roger SHIVELY
Hello @SHiroshi19 ,
This post has been escalated to the ST Online Support Team for additional assistance.  We'll contact you directly.
Roger
