2003-08-19 5:30 AM
2011-05-17 2:55 AM
Hi every body.
Is it possible to use the USB port for the ISD-51 instead of the UART port? (The UART port can serve also as GIO). Thanks Kobi.2011-05-17 2:55 AM
I don't think so, since the ISD-51 macro provided by Keil uses the UART port, you may want to contact KEIL support at:
http://www.keil.com/support , to see if they have anything.
