How can I program the EVAL-IPFC01V1?
‎2018-02-20 4:48 AM
Yesterday I started to work with the EVAL-IPFC01V1.
Can I program the STNRGPF01 with the ST-LINK/V2 through the SWIM connector J2?
Or I must use the UART J3 with the adapter in the box? In this case what is the correct FTDI cable model?
Best regards
#eval-ipfc01v1 #stnrgpf01- Labels:
eDesignSuite
‎2018-02-20 5:34 AM
Dear Mr Giovanni,
Thank you for your interest on ST products.
In blog post (
https://community.st.com/community/edesignsuite/blog/2017/11/29/stnrgpf01-programming-tool
) explains in detail how to proceed for uploading the firmware generated by eDesignSuite within the STNRGPF01 device.
About the FDTI cable, it's recommended to use the following item:
TTL-232R-3V3
USB to TTL Serial cable (3.3V)
(i.e
https://it.rs-online.com/web/p/kit-di-sviluppo-interfacce/0429307/
)About the possibility to re-insert the custom firmware for 'EVAL-IPFC01V1' in the next days I hope to
publish
a new post blog about this issue.Best Regards
Carmelo
‎2018-02-20 7:05 AM
OK.
I'll try it in the next days.
Best Regards
Giovanni
‎2018-12-14 2:31 AM
I posted a topic where I described how to reprogram a STNRGPF01...
Not trivial but easy to do
