hi Sjo,need your help for ST7Flite19
‎2004-07-16 12:39 AM
- Labels:
Legacy Products
‎2004-07-04 11:05 PM
i had downloaded the source code of ST7Flite19 from www.spen-soft.co.uk and referenced the code. but why after programming the
option byte, the device will not enter the ICC mode. if programming the default value, still appear this problem. can you help me? thanks a lot. best regard Mike- Mark as New
‎2004-07-06 12:11 AM
Could you explain what source code you have downloaded, there is no code for the flite29 on my site.
Regards sjo- Mark as New
‎2004-07-12 5:41 PM
sorry, my mistake. i had download xflash-lite2 source code. for i even have lite29 device, so i tested it. but after progrmming option byte, can not enter
ICC mode again.- Mark as New
‎2004-07-12 9:49 PM
Sounds like you have messed up option byte config.
The recovery procedure will be to ignore option bytes (external clock must be provided). Regards sjo- Mark as New
‎2004-07-16 12:32 AM
thanks for your reply.
i want to make sure that if you program the option byte not including FMP_W bit, you can reprogram them again?- Mark as New
hi Sjo, can you give me your MSN? i want to talking with you about ST7.
