Hi, Is it possible to have any mathematical dependencies, even approximate, between EEPROM FIT values and supply voltage? Thank you.
Options
2020-04-06 9:19 AM
This might be a very basic question: EEPROM FIT values are based on standard single value of Ea = 0.7 eV. Is it irrelevant to supply voltage? I mean using lower supply for wide range device might reduce FIT values. Are any mathematical dependencies, even approximate, based on supply voltage? Thank you.
Labels:
EEPROM devices
1 REPLY 1
Options
2020-04-07 1:27 AM
The FIT given is different (or not) because it is mostly based on the technology used to manufacture the eeproms.
Can't give even an approximate mathematical dependency.
BR
