Firmware upgrade : USB + DFUSE. How ??
Options
2008-06-19 1:04 AM
Posted on June 19, 2008 at 10:04
Labels:
- Labels:
Legacy Products
1 REPLY 1
Options
2008-06-19 1:04 AM
I trying to implement a USB application on my STR711 for download new firmware from DFUSE application. I downloaded the USB firmware library from ST (um0290.zip) I use IAR Workbench 5.11 and if I compile the project, it returns me several errors on INIT_TAB.s file Bad instruction COMMON INTVEC:ROOT Bad instruction COMMON INTVEC_ROM:ROOT Invalid Syntax DCD sfe(INTVEC_ROM) - sfb(INTVEC_ROM) Invalid Syntax DCD sfb(INTVEC) Invalid Syntax DCD sfb(INTVEC_ROM) I have never used this file before. What is the purpose of it? What is wrong? What I have to change to compile correctly? Thank you for you help, I appreciate very much ALFA
