2006-08-08 10:04 PM
difference between Program Flash and Data Flash
2006-08-08 2:11 PM
I'm a new on STR711, and planning to use it very soon. I saw that there is defined data and program flash. Is it means that we can not write data in the program flash (i.e. constants)? What is the sense of splitting flash for two regions? As far I know in LPC2000 i.e. there is continuous memory definition. Could you please explain it to me, it is very important to make final decision about ARM we will use finally. Thank you in advance, Kind Regards I.M.2006-08-08 10:04 PM
Many thanks for your prompt answer.
Excellent, So, we will use for our design STR712. Kind Regards I.M.
