Difference between FW and FAW chips
epellini
Posted on February 26, 2008 at 04:41
epellini
Posted on May 17, 2011 at 09:50
Hi friends, I was using an ARM9 STR912FW44 in my projects.
Last week i was projecting another system and i was searching ST Microelectronics website for the STR912FW44 datasheet.
Surprisingly i found that there is another STR912, but this time it has FAW44 on the chip spec. What this FAW means ?
I downloaded both datasheets and i found no difference between them.
Thanks for the attention
DocHell
jilisegiar
The STR91xFxxxxx are the first samples with silicon revision B and D and the STR91xFAxxxxx are the last samples(production devices) with silicon revision G and H.
Refer to STR91xFA errata sheet for more information:
http://www.st.com/mcu/modules.php?name=mcu&file=familiesdocs&FAM=101#Errata Sheet
