2004-12-29 12:26 AM
contents of Internal RAM space after block switching
2011-05-17 2:57 AM
i would like to know whether Internal RAM (indirect or Direct Addressing space) location will be afftected by block switching or not? eg: If we write (using simple mov instruction) to location 0x60 some specific value while executing from primary flash .& After that if we simply do the block switching from primary to secondary flash & try to read the location 0x60 .Whether the contents of this location will change??or remains the same? Purvi
