2003-10-27 01:51 AM
2003-09-03 04:29 PM
hello
I have a target board of infineon C167cr-Lm ,it work correctly . now I replace C167 with the ST168 . and it can't enter the bootloader mod. could you give me some advice . thank you.2003-10-23 10:22 PM
Even so the parts are very similar, they are not identical and some care should be taken when replacing.
I recommend to check the following document page 248 and to compare with infineon similar documentation.http://www.stmcu.com/mcdfiles/7pdf
You should also be careful regarding pin Vpp/RPD (refer to this discission:http://www.stmcu.com/forums-cat-87-5.html
finally find enclosed a related application note, knowing that ST10R167 and ST10F168 are fully compatible (except for the program memory) [ This message was edited by: Max on 27-10-2003 15:13 ] ________________ Attachments : comp_ST_Infineon.pdf : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I0GR&d=%2Fa%2F0X0000000bYj%2FUuB1VSshb4P.54aYlOu4H527jyh_.0hvDlNoO9EAsN8&asPdf=false2003-10-27 01:51 AM
when first posted, the previous message attachment was an obsolete version of the document .
If yo used it, please dowload it again!
