Buffered and unbuffered
frasker
Posted on June 30, 2009 at 21:53
frasker
Posted on May 17, 2011 at 09:58
What is the difference between buffered and unbuffered peripheral memory map?
frasker
can anyone help?
rich2
My understanding is that buffered writes are done asynchronously (to the peripheral) while unbuffered is synchronous. In other words, when you write to an area in the memory map defined as 'unbuffered' and then immediately read back, you are guaranteed to see the results of your write.
HTH,
Rich
