buck-boost converted with feedback using NUCLEO-H753ZI
qinjie
Visitor
Is it possible to use the NUCLEO-H753ZI board to vary the PWM signal to the mosfets so to achieve constant output voltage? the input voltage will be always varying. If so may I know how should I do it?
0 REPLIES 0
