ARTimer ST7LITE02
Options
‎2005-09-28 10:01 PM
3 REPLIES 3
Options
‎2005-07-19 3:38 AM
Posted on July 19, 2005 at 12:38
in compare mode the timer not work correctly. I see the AN1753 but the routine not work on ST7LITE02. Help me if possible with simple routine that make a square wawe of 10Khz. Thank's by BIFFO Sorry for my ''incredible'' english :-]Options
‎2005-08-08 9:36 PM
Posted on August 09, 2005 at 06:36
You can use the ST7 software library having the 12-bit Auto reload timer peripheral. It can be downloaded from the same site.
Options
Posted on September 29, 2005 at 07:01
Sorry, but I see now your reply.
I've download the ST7 library, but are C library. I work in ASM, you can help me with example in ASM. Thanks
