Application note for converting RVDK project to IAR EWB project
chander
Posted on September 04, 2006 at 07:41
chander
Posted on July 18, 2006 at 06:56
Does there exist some application note which tells how to port a RVDK project to IAR EWB project. All of the source code available on the site is based on RVDK. It is almost impossible to port the code on IAR Embedded WorkBench without some help.
bingo_2046
Posted on September 01, 2006 at 20:50
You can find it from the Setup dir--''C:\Program Files\IAR Systems\Embedded Workbench 4.0\ARM\doc\''
There are an Application notes---EWARM_RealViewMigrationGuide.pdf
