2004-01-29 02:25 AM
Anyone here using NMI with Atlas?
2004-01-12 10:09 PM
I need to trigger a NMI routine with Atlas in Local Bus mode (no ISA bus available): I'm trying via PCI bus error signal /SERR, but it doesn't seem to work. Any hints? Thank you in advance Fabware.2004-01-14 03:07 AM
Hi Fabware;
With Atlas in Local Bus mode no access can be provided to internal NMI signal. This is an issue wich has not been resolved but it works fine In ISA mode. Unfortunatly no ISA bus available for you.2004-01-29 02:25 AM
So there is NO OTHER way to trigger NMI?
Even after watchdog counter expiration? Thank you. [addsig]
