Advantages of DSP library
Posted on April 27, 2005 at 07:55
I want to use the arithmetic functions of the DSP library to optimize a controller function. Does the involvement of the MAC unit really give an advantage in time.
e.g the normal operation c=a-b where a,b,c are of type int takes 10 instruction cycles
but the use of sub_16(...) of the library uses also 10 instruction cycles (see pdf file)
How can I use the DSP library to optimize a function which uses fix point variables?
Thank you very much for your support.
________________
Attachments :
st10dsplib.pdf : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I09Y&d=%2Fa%2F0X0000000bYl%2F0byxZpz9AZLhKONDkJZ6sc8Yys0igbqbc2srhndW4mw&asPdf=false
