2006-05-02 09:58 PM
2006-05-02 09:58 PM
Hi to all,
is it possible to perform an interrupt on USB pheripheral by reading (PC side)? In other words, I'm creating a firmware that use USB with a single EndPoint in reading (STR7 -> PC), then I modified usb_conf.h with below command line: #define EP1_Callback EP1_isr //EP1_isr Interrupt Endpoint Routine By PC side, nevertheless, when I perform a reading, the interrupt does not generated then EP1_isr does not executed!!! I hope that is a my error, could you help me to found it or suggest another solution? Thanks in advance to all null#define EP1_Callback EP1_isr
