trouble with ISR driven UART + loopback
michael
Posted on April 09, 2008 at 07:08
michael
Posted on May 17, 2011 at 09:51
Hello all,
Here is the situation: I configure my UART to support loopback and to generate an interrupt when the fifo is 1/2 full but it goes wrong even if the fifos are disabled. the thing is that even I do acknowledge the interrupt, the ISR is invoked for the same character! Please note: this happens even if I send a single character!
This is the ISR:
Code:
<BR>unsigned char l_data = UART1->DR ; <BR> <BR> <BR> UART_ClearITPendingBit(UART1, UART_IT_Receive) ; <BR> //UART_ClearFlag(UART1) ; <BR> <BR> VIC0->VAR = 0; // Acknowledge Interrupt <BR> VIC1->VAR = 0; // Acknowledge Interrupt
UART1->DR keeps on containing the same character!
I know the UART works, because when I disable UART1_IMSC's RXIM bit, interrupts are not longer generated but the data ends up on the bus (still looped back though...).
Can you help me?
[ This message was edited by: michael.tamir on 09-04-2008 09:15 ]
kais
could you please calrify more:
what do you mean by this?
''the ISR is invoked for the same character! ???''
Eris.
michael
Hello and thanks for your reply,
I mean that every time the ISR is invoked, I read the same character from the DR register! The ISR is invoked continuousely, delivering the same character.
