Timer 1 ms with STR75 and Raisonance print
xaviooo
Posted on May 23, 2007 at 10:45
xaviooo
Posted on May 22, 2007 at 15:21
Hello everybody,
I'm trying to create a 1ms timer with a STR750 microcontroller.
void TB_Configuration(void)
/* TB configuration in Timing mode */
TB_InitStructure.TB_Mode = TB_Mode_Timing;
TB_InitStructure.TB_ClockSource = TB_ClockSource_CKTIM;
TB_InitStructure.TB_Prescaler = 29; /* TB clock = 60MHz / (29 +1) = 2 MHz*/
TB_InitStructure.TB_CounterMode = TB_CounterMode_Up;
TB_InitStructure.TB_AutoReload = 19; /* update each: 2 MHz/(19+1)= 100 KHZ ---> 10 us */
TB_Init(&TB_InitStructure);
TB_ITConfig(TB_IT_Update, ENABLE);/* Enable TB update interrupt */
TB_Cmd(ENABLE); /* Enable TB counter */
.... //EIC ENABLE
void TB_IRQHandler(void)
INC_10us++;
TB_ClearITPendingBit(TB_IT_Update);
Works
void WaitClock(u16 time)
while (INC_10us < time)
Here is the problem
print('' INC_10us: %d \r'',INC_10us);[/B] // Raisonance print
INC_10us = 0; //Reset counter
main
... // INIT
while(1)
WaitClock(100); // Wait 10 * 100us = 1ms
Problem
In the function WaitClock, when I don't use the function print, i'm stuck in the while of the function.
When I use the function print, it works, but the timer is a 20 ms timer instead of a 1 ms timer.
Of course, I'd prefer not to use the function print.
Is there an obvious mistake ?
Did anyone have the same problem ?
Thank you again.
-Xavier
xaviooo
Well,
First problem solved : print function takes too long :-? .
I have a 1 ms timer:).
Second problem :
This works... but it's ugly... It's the best I can do for now?
Here is the problem
GPIO_WriteBit(GPIO0, GPIO_Pin_4, 0);
Why this doesn't work ?:
while (INC_10us < time);
