STVP7 / ST7FLITE29 and option bytes
tomas2
Posted on December 04, 2003 at 02:53
tomas2
Posted on December 01, 2003 at 15:18
coming from ST62, I am new on ST72-series and need your help.
I shall program a ST7FLITE29 installed in design-kit ST7MDT10-EPB using STVP7 ST7 visual programmer.
My goal:
At 5Vdd run the internal RC oscillator (=1MHz) to produce 8MHz and enable LVD at optimum level.
Please point out the correct option byte selections for:
''OSC RANGE''
''PLLx4x8''
''PLL OFF''
''PLL32 OFF''
''OSC''
''LVD''
I would be grateful for any tip.
Tomas
jatin
Posted on December 03, 2003 at 12:11
The option byte settings for your requirement are-
''OSC RANGE'' - Select default value(i.e external clk source-CLKIN on PB4)
''PLLx4x8'' - PLLx8
''PLL OFF'' - PLL enabled
''PLL32 OFF'' - PLL32 Disabled
''OSC'' - '' RC oscillator ON''
''LVD'' - Select LVD level as per your requirement
tomas2
Many thanks !
Best regards,
Tomas Fahlman
