2003-04-03 01:22 AM
2003-04-03 01:22 AM
I am new to Atlas programming and I am interested in watchdog register programming. In datasheet the register are identified with a offset from a base I/O address which is variable and must be programmed in a way that is not clear ... (RBI interface ) a similar technic is used for Local Bus reg access ( and it works ) but I am not able to access Watchdog registers. Thanks
