2005-01-18 11:39 PM
ST92F150 problem,can you help me ?!
2011-05-17 02:36 AM
I used a test program testing my chip .
it's work well on the ST9 HDS2V2 EMULATOR, but it doesn't work in chip. (power 5V,CRYSTAL SCILLATOR 0.6V,4M). it's I/O PIN output only 0.3V or so!!!? can you tell me how to do with the problem ?2011-05-17 02:36 AM
Is your Hardware throwing the Correct Reset to the micro?
Check it on Probe Is the Watchdog hardware or software enabled? Check Pin No 97. what is your application?
