ST92F150 problem,can you help me ?!
misshyx
Posted on January 19, 2005 at 08:39
2 REPLIES 2
misshyx
Posted on May 17, 2011 at 11:36
I used a test program testing my chip .
it's work well on the ST9 HDS2V2 EMULATOR, but it doesn't work in chip.
(power 5V,CRYSTAL SCILLATOR 0.6V,4M).
it's I/O PIN output only 0.3V or so!!!?
can you tell me how to do with the problem ?
kapil
Is your Hardware throwing the Correct Reset to the micro?
Check it on Probe
Is the Watchdog hardware or software enabled?
Check Pin No 97.
what is your application?
