ST10F275 ECU 7.9.9
arleilauer
Posted on July 26, 2009 at 19:35
ST10F275 ECU 7.9.9
#st10-bsl
4 REPLIES 4
arleilauer
Please help -me
Initializing ST10Flasher.dll
Init COM2 at 56000 bauds
*LOAD MONITOR-->OK
*Dump-->ERROR
Description: LoadExternalFlashMonitor: target Not found
Select All blocks not creat dump... Error ''target not found''
rmacedorj
Posted on May 16, 2010 at 21:17
Mostrar romanização
I'm also having this problem I believe is the version of the program would have someone younger to be able to send me please I'm on version 2.4
thanks
email.
rmacedorj@oi.com.br
algontsov
Posted on July 06, 2010 at 21:01
The MCU is just not in the BSL mode, check the voltage of PL.04 (must be close to 0) and PL.05  (to +5).
Posted on November 16, 2010 at 20:27
I've got this problem too, i'm not sure it was the BSL because when i try to save in format .txt, it run properly ! when i choose format .hex...ive got th error....
