Serial EEPROM SPD ST:M34E04B-FMC9TG
Hillary
SGS report indicates Test sample: LEAD FRAME; Item no.: C7025-UPG RT, the substance normally include Cu/Ni/Si/Mg, but according to M34E04B-FMC9TG material Composition Declaration file, the substance include Cu/Fe/Zn/FeP, please advise if the substance is correct or not.image.png
Douglas MILLER
This forum thread was marked by the moderator as needing a little more investigation, so a Support case was created in your name and will be handled off-line.
