SDRAM
cdvehicle
Posted on January 26, 2005 at 07:08
SDRAM
cdvehicle
Posted on January 18, 2005 at 23:35
hi all:
In consumeII's datasheet the sdram controll use CS0#/CAS0/RAS0 to solid sdram, but in reference sheet
it use cs0/cas1/ras1. why????
kaouther
I checked in the ConsumerII's datasheet & the reference schematics we used the same for the solid sdram. You have confused with the SDRAM DIMM.
