2006-11-07 06:47 PM
2006-11-07 06:47 PM
I have ST72264 SCI protocol question. This is copied from Datasheet:
Bit TC is cleared by a software sequence (an access to the SCISR register followed by a write to the SCIDR register). My question: Is it necessary that these two instructions are followed directly each by other or is it possible to insert some other instruction(s) in between? Thank you.
