2024-11-14 01:32 AM
Greetings Community,
I am using the STHV800 ultrasound pulser in the analog front-end of an ultrasound imaging application. In my setup, I pulse at ±50V, generating a 3-cycle biphasic signal at 5.2 MHz for transmit. The transducer is connected via a 2-meter twisted pair cable; 70-ohm impedance match.
I am evaluating potential fault scenarios where:
Thank you for your assistance!
Best regards,
Raghavendra Padmanabha
