2009-04-23 07:08 PM
Raisonance RIDE 7 compatibility with STR91xFWxx and STR91xF
2011-05-17 12:58 AM
I would like to know if it possible to use Raisonance Ride 7 compiler for controller STR91xFAWxx. When I go in ride 7 options, I can select a STR91xFWxx device but not a STR91xFAWxx (char “A� is missing). Is it compatible? Thanks in advance, Julien.2011-05-17 12:58 AM
Yes, you can work with the ''A'' device by selecting the ''non-A'' equivalent in Ride. Upon connection, Ride will automatically detect that you have a ''A'' version and act accordingly when (if) it makes a difference. Best Regards, Vincent (Raisonance)2011-05-17 12:58 AM
Thank you for this quick and clear answer !
Julien.
