PWM output on T1_OCMPB
pascal_rajagopalan
Posted on June 13, 2006 at 10:20
pascal_rajagopalan
Posted on June 13, 2006 at 09:34
Hi!
I'd like to know if I could use the T1_OCMPB pin (1.6) as an output PWM pin instead of the T1_OCMPA pin? I didn't manage to get it toggling.
gpoirier9
I don't think you can use OCMPB pin. Datasheet said only OCMPA pin for output PWM : it's certainly due to implementation of timer.
If you need absolutely use OCMPB pin with a PWM signal, you can create this signal using 2 output compare Register and interrupt !
