2003-06-10 08:35 AM
2003-06-10 03:59 AM
When I use strap resistors with value 470K, system strap cannot work. Change value to 2K, it works fine. Any value greater than 2K will not work.
When strap DACKEN0-DACKEN2, I use 1K resistors.Any value greater than 1K will not work. Use devices: Main chipset: STPC ATLAS SDRAM memory type: HY57V641620HG T-H DACKEN0-DACKEN2 decode by 74HCT138 Is there any problem with my board?2003-06-10 08:35 AM
I have a similary problem too. Please have a look here ''http://www.stmcu.com/forums-cat-431-6.html''
Sometime the problem is still there. So I will check if a value of 1K will solve my problem too. Benno
