Problem with interrupt mask
charlu
Posted on March 15, 2007 at 13:30
10 REPLIES 10
kmshim
Posted on May 17, 2011 at 09:34
hi,
I thought that this problem comes from nested interrupt.
you must consider stack size on nested interrupt.
basically, IRQ exception procedure is implemented as following
user(or sys)mode --> IQR mode --> user(or sys) mode
--> IRQ mode --> user(or sys)mode
finally, reset or hang-up occured
therefore large stack of user(sys) is needed.
if you do not need to use nested interrupt,I recommand that disable interrupt on macro switching IRQ to user(sys) macro in the 91x_vect.s
good luck.
Best regareds
KMSHIM
