power LED off when connecting Jlink!?
hg-chen
Posted on April 20, 2007 at 23:41
5 REPLIES 5
hg-chen
Posted on April 20, 2007 at 12:19
STR750-SK/IAR is used,
set jumper to EXT power, connect 9V DC to power jack,
the power LED is on and message displayed on LCD panel
but when I connect Jlink to the board,
the power LED is off!?
any idea what happened?
note that there is no problem with this Jlink connect to STR710-SK/IAR
and external 9V DC supply!
hg-chen
Posted on April 20, 2007 at 22:55
I connect 9V DC with jumpper set to EXT,
then connect Jlink, and the power LED goes off,
and I execute the Jlink.exe
the message reply in DOS prompt are
SEGGER J-LINK Commander V3.10b ('?' for help)
Compiled Feb 9 2006 20:21:29
Can not connect to J-Link via USB
J-Link>
hg-chen
Posted on April 20, 2007 at 23:01
Sorry for my careless,
I forget to connect Jlink to PC with last action,
now the message replied with executing jlink.exe are
SEGGER J-Link Commander V3.10b ('?' for help)
DLL version V3.10b,Compiled Feb 9 2006 20:21:16
Firmware : J-Link compiled Feb 8 2007 10:49:18 ARM Rev.5
Hardware : V5.40
S/N :15400606
OEM : IARKS
Vtarget - 0.000V
Speed set to 30 kHz
J-Link>
hg-chen
Posted on April 20, 2007 at 23:32
I measure the Jlink pin 19 (connect Jlink to PC USB) , but no 5V out put as it should be !?
any action to activate the Jlink pin 19 voltage output?
hg-chen
sorry for all the mess ,
the Jlink is mis connect to the AIN connector to cause the problem !
