PLEASE!! *any* working examples for Hitex comStick??
dan1
Posted on June 11, 2008 at 21:51
dan1
Posted on May 17, 2011 at 09:53
Other than the examples that actually come with the comStick itself??
This has been driving my nuts:
1. The Hitex examples *only* work with the version of toolchain that it comes with
(V4.0.3).
2. Their examples don't use gcc to call ld/as, they call these tools directly,
pathing to an unexpected path for the libraries.
3. If I try to change their code to call through gcc, I cannot make it find
the correct library path, no matter how many different places I specify the
path.
4. If I try any other GnuArm toolchain, I can never get the project to build.
I either get floating-point inconsistencies, interwork inconsistencies,
or other system functions not found (CodeSourcery).
I DESPERATELY need to find a simple project that builds with any of the standard tools (Yagarto would be a good choice), and can just simply toggle the status LED on the comStick board!!! (port 9 pin 0 or port 4 pin 1, where I also have an LED, which only Hitex is able to toggle!!).
Can anyone give any pointers for this??
