2004-05-11 08:56 PM
memory model and link command file settings of ST72F521
2004-05-11 08:56 PM
hi sjo,
it is a mistake of me: I do not use IAP but ICP (In Circuit Programming)!!!!! There is no need to keep my application running during programming. But there is one error if I use it with the datablaze. If the software is downloaded on microcontroller and I take off the connector of the programming tool (inDart-ST7F) my application do not run. Is there any settings which I can change that the application is running (also after voltage breakdown)? chris
