2021-12-09 11:12 PM
I saw two version of subjected item at EE marketing , is different on body marking , one is 404RP, the other is 404RB, so I would like to know the distinguish between them on electrical parameter? can alternative to use?
2021-12-13 01:24 AM
404R8 is for range 8 ( M24C04-DRE)
404RP is for range 6 ( M24C04-RDW6TP)
Not the same temperature range / not the same die / not the same performance.
BR
2021-12-13 05:35 AM
2021-12-14 12:02 AM
Datasheets are available on ST.COM portail.
https://www.st.com/resource/en/datasheet/m24c04-dre.pdf
https://www.st.com/resource/en/datasheet/m24c04-r.pdf
BR
