2024-09-10 11:55 PM - last edited on 2025-02-03 7:24 AM by Peter BENSCH
We use custom carrier board and ST33TPHF20SPI in our products.
We need help with Linux driver (kernel < 6.0) and integration help. We only found instructions for Pi boards.
2025-02-03 7:26 AM
I have just come across your older question: the data of all ST33 devices is strictly confidential and will only be handed over if an NDA is signed. For this reason, nobody in the public community will be able to help you, so you should contact your local ST contact.
Hope that helps?
/Peter
2025-02-03 7:26 AM
Hope that helps?
/Peter
2025-02-03 11:19 AM
Thank you
