lcd query
sjo
Posted on February 10, 2004 at 10:44
lcd query
4 REPLIES 4
sjo
Posted on May 17, 2011 at 11:58
I notice in your examples for the DK3200 PortA (peripheral mode) is used for lcd data.
In the past I have used P0 (address/data) for lcd data - this method was also used on the DK900 dev boards - is this possible with the uPSD.
I cannot see any reason why not but thought I would check here before I try it. This would then free PortA for GPIO.
Many Thanks
sjo
joseph2399
According to page 47 of the uPSD 323x data sheet,
(http://www.st.com/stonline/books/pdf/docs/9188.pdf), Port 0 and Port 2 are dedicated external address and data bus and can NOT be used as GP I/O or Peripheral I/O mode.
sjo
I know they are dedicated, as they are on all 8051 with external memory.
My question is can a upsd be attached to an lcd on p0 as the DK900 kit was.
I have attached schematic of what I mean.
sjo
sjo
As I said before attaching an lcd to P0 is quite common on the 8051 world so I thought I would try it anyway.
I have done this on the DK900 kit with an 8031 attached.
It can be done and works very well. I have attached the code so everyone else can use a lcd on P0, thus saving a port.
The only improvements is to use either PA or PB (bits 0,1) for the RS and RW lines , this would save having to use the cpld.
Simply write 0x03 to the CONTROL register (address out) and set the DIRECTION as output - this can be done at runtime.
sjo
