2024-03-14 07:49 AM
I can't find any information about the IC shown in the picture attached. It seems to be a very very old part that is no longer in production and ST support do not have records for anymore.
Can you help find a datasheet or an equivalent component?
2024-03-14 08:33 AM
Perhaps TS902 op amp
Rail to rail CMOS dual operational amplifier (with standy position)
2024-03-14 08:33 AM
2024-03-15 04:51 AM
Good morning,
I checked the TS902 datasheet and it is consistent with the circuit under examination. And definitely the right component.
Thank you for your suggestion
Greetings
Massimo R
