I2C BUSY flag not set in I2C0_SR1
jonathan2
Posted on February 19, 2009 at 07:00
2 REPLIES 2
jonathan2
Posted on May 17, 2011 at 09:56
Hi.
I am trying to write two bytes to a I2C0 peripheral as master at 400kHz using interrupts [haven't tried it with polling]. When I send a start bit I get an interrupt but the I2C0_SR1 register does not have the BUSY flag set, so the state machine goes to pieces.
More detail:
STR911FAW42 (G silicon) on custom board
ST libraries turfed
Non-nested IRQ handling with irq vector set to:
0018: ldr pc, [pc, #-0x0FF0]
[Interrupts working OK for UART0 driver]
I2C device = AD5243 (dual digital potentiometer)
I2C clock = 400kHz
PCLK = 48MHz (cpu running @ 96MHz)
No other I2C devices
Only want to transmit (ie don't need to read)
No other interrupts are occuring when the i2c transfer is started
The I2C initialisation is:
SCU_PRR1 &= 0xFFFFFFBF;
SCU_PRR1 |= 0x00000040;
I2C0_CR = 0x00;
I2C0_ECCR = 0x00;
I2C0_CCR = 0xA5;
I2C0_OAR1 = 0x01;
I2C0_OAR2 = 0x80;
I2C0_CR = I2Cbit_PE;
iic_progress = IICstate_BUSY;
I2C0_CR = I2Cbit_PE | I2Cbit_START | I2Cbit_ITE;
NOTES:
I2C0 peripheral is reset each time I try to send because of another forum message which mentioned bus bouncing but it has made no difference
I2C0_OAR1 set to the ignored slave address (0x01)
iic_progress is a local variable to indicate whether i2c transaction is complete
If I don't set I2C_CR twice (once without the start bit, then with the start bit) no start bit is sent...
The interrupt service routine is:
void iic_isr (void) __attribute__((interrupt));
void iic_isr (void) {
unsigned long state;
static unsigned char iic_iteration;
state = ((I2C0_SR2 << 0x08) | I2C0_SR1) & 0x3FFF;
switch (state) {
case I2Cstate_EVENT5:
/* send slave address */
I2C0_DR = (ADnum_SLAVE_ADDRESS << 0x01) | IICact_WRITE;
break;
case I2Cstate_EVENT6:
/* clear event 6 */
I2C0_CR |= I2Cbit_PE;
/* becomes event 8 - send first data byte */
I2C0_DR = iic_data[0x00];
iic_iteration = 0x00;
break;
case I2Cstate_EVENT8:
/* first time send second byte of data, second time generate
* stop condition
if (iic_iteration == 0x00) {
I2C0_DR = iic_data[0x01];
} else {
I2C0_CR |= I2Cbit_STOP;
iic_progress = IICstate_COMPLETE;
iic_iteration++;
break;
default:
/* some error */
iic_progress = IICstate_ERROR;
I2C0_CR = 0x00; /* kill the error */
VIC0_VAR = 0x00000000;
VIC1_VAR = 0x00000000;
NOTES:
This isr does _everything_ (as far as I can tell) that the ST library functions do in the i2c example without the obfusction of a plethora of function calls and worrying about whether we're transmitting or receiving.
VICx_VAR is written because of the non-nested interrupts
No handling of event 7 since we are transmit only
When the isr is called (after sending a start bit) the value of I2C0_SR1 is always 0x83 (EVT, MSL & SB flags set, but BUSY flag is not). This causes the default case to be called and no transfer occurs. On the I2C bus I get a start bit and then nothing else.
If I ignore the fact that the busy flag is not set (and write the slave address to the I2C0_DR register) I get a 3.5us delay followed by a 400kHz clock which never ends with the data line SCL held low [and no more interrupts]
If I ignore the fact that the busy flag is not set (and just exit the isr waiting for busy flag to become set) I get infinite interrupts so the application effectively hangs and the clock line is held low after the start condition.
Does anyone know what I might have done incorrectly, or from where this problem has arisen?
Jonathan Pratt
davidfussell9
Hi Jonathan,
I guess from the age of your post you've resolved this issue, but since I've been a victim of the same problem I thought I'd post details of what I had to do to get things working (which relates to the GPIO port setup):
I'm using P0.0 and 0.1 as I2C0 SCL/SDA, so my port config is:
Code:
GPIO_StructInit (&vl_GPIOInit);
// Pins 0, 1 as I2C0
vl_GPIOInit.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 ;
vl_GPIOInit.GPIO_Direction = GPIO_PinInput;
vl_GPIOInit.GPIO_Type = GPIO_Type_OpenCollector;
vl_GPIOInit.GPIO_IPInputConnected = GPIO_IPInputConnected_Enable;
vl_GPIOInit.GPIO_Alternate = GPIO_OutputAlt2;
// Write config to port
GPIO_Init(GPIO0, &vl_GPIOInit);
Which is fine, until I configured P2.0 and P2.1 as CTS/DTR for Uart0:
Code:
// Apply defaults to IO structure
// Pins 0 and 1 as UART0 CTS & DSR (inputs)
vl_GPIOInit.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1;
vl_GPIOInit.GPIO_Type = GPIO_Type_PushPull;
// vl_GPIOInit.GPIO_IPInputConnected = GPIO_IPInputConnected_Enable; // WRONG!!
vl_GPIOInit.GPIO_IPInputConnected = GPIO_IPInputConnected_Disable; // RIGHT !!
GPIO_Init(GPIO2, &vl_GPIOInit);
My mistake was to enable the 'alternative' input function of these pins, since that creates a second pair of SCL/SDA lines to the I2C0 device.
Disabling the alternative input (as shown) ensures the busy bit gets set following generation of the start bit.
Hope this helps someone-
Dave
