How to run a program?
kebap
Posted on May 11, 2005 at 04:31
3 REPLIES 3
kebap
Posted on May 17, 2011 at 12:06
Hello!
We have a problem with our uPSD3254a.
We have load a demo-program(initialize a display and put out a character)
with PSDsoft Express to our microcontroller,but the LCD doesn't display anything.
Does a start condition for the microcontroller exist?
What have we to do, to run the microcontroller.
Regards preines
rk1
hi,
no, there is no ''start condition''. but make sure to configure/trigger or disable the watchdog.
if you want to know if the microcontroller is running, configure 1 pin as output and toggle it in an endless loop, and then look at the pin (i.e. with an oscilloscope).
thomasthanner9
there are actually two conditions that can stop a uPSD from running. First is the Watchdog as already mentioned by rk__. Second is the pullup at the USB_D- pin. This pullup is required even on non USB-devices. Maybe that is what is missing from your design?
