Does USB disable other UARTs on uPSD chips?
dsalgueiro23
Posted on January 16, 2004 at 20:18
dsalgueiro23
Posted on May 17, 2011 at 11:57
Hello all,
I'm interested in the uPSDs with USB capability. If I use the USB port, can I also use the 2 UARTs independantly? How many I/O pins do I give up for each UART and USB port?
I can't get to the uPSD manuals on ST's site right now, seems to be down.
Thanks for your info.
joseph2399
Yes you can use them independently. uPSD has dedicated USB ports therefore will not consume I/O pins. Each UART requires two I/O pins, (i.e. TxD and RxD). I just checked our website, it appears to be O.K., please try to use the link below:
http://www.st.com/stonline/products/families/memories/psm/ds.htm
