2004-11-24 06:07 PM
2004-11-23 03:42 AM
I am using the ST72F262G2 and I found at page 170 of the datasheet section 19.6 (Errata Sheet) that ''If LVD is disabled, the internal RC oscillator clock source cannot be used''... Is this still true? Does anyone know why? Thanks in advance Clearco2004-11-23 10:07 PM
Yes, its still applicable.
2004-11-24 12:16 AM
Does this limitation apply only to microcontrollers with trace code marked xxxxxxxxxZ as told in the errata sheet (page 168 section 19)? Is there some risk that this limitation applies to some other stocks of microcontrollers?
Thanks so much Clearco2004-11-24 06:07 PM
It is only for the device with trace code marked xxxxxxxxxZ which is the only one in production.
