2005-02-04 03:05 AM
CAD files for STR710 and STR720 Eval Boards
2005-01-28 02:15 PM
Can someone please supply me with CAD source files for the STR710 and STR720 Eval Boards ? (I presume they were developed using Orcad - most eval boards are ...)
2005-01-31 12:18 AM
Hello cadrjr,
Please can you explain ,what does means ''CAD source files '' it is a matter of ''gerber'' file or not ? With regards. Hich :-]2005-01-31 04:33 AM
I principly mean the Schematics in Electronic format (ORCAD, etc). (I have them in .pdf format already.)
Also any Layout files would be useful - files containing the device footprints would save me having to re-enter them all again. Gerber files are of no use. (The files I need are *.opj, *.dsn , *.olb and *.max if Orcad was used) Thanks :-)2005-02-01 03:09 AM
Hello cadrjr,
Our design engineer use the Mentor tool to develop the Electronic Schematics and Gerber file is the only file we've got. Hope that helps. Best regards, Hich. :-P2005-02-02 07:36 PM
Hello cadrjr
You find attached the mentor files attached with this message. Hope that helps! Cheers Hich :-P ________________ Attachments : mb393a.zip : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006Ht9a&d=%2Fa%2F0X0000000aJh%2F4j_WtyhOPzM2d2Hkj7Wqv3Xp6aGgNt78TQmXdkXN6d8&asPdf=false2005-02-04 03:05 AM
Thanks - but these are only Gerber filers for PCB manufacture.
