missing-QuestionPost
Resolved! Could not enter WKUP ISR
Hello,My target is SPC560B54L3 and using SPC5Studio with componentsI saw SPC560BCxx IRQ example and followed into my application.I would like to use PC11(WKUP5, WakeUp_IRQ_0)and I checked WISR value is changing when I switch PC11 but ISR code doesn't...
Can i put progrom by JTAG directly.
hello, i want to produce the same frequence in 8 channels,Can i put progroms by JTAG to FPGA .OR in other words, i want to know whether the STHV800 chip can just receive the file format of"dfu" or i need transform the file format.thank you !
YDENG.9 by Associate II
  • 315 Views
  • 0 replies
Problems with PWD13F60 on my own pcb desing
Hi, currently in my application i am handling an inductive load without problems with the evaluation board of PWD13F60, but when I use the IC in my 2 layer PCB design it explodes when applying 310VDC, with voltages lower than 250VDC approximately it ...
FGall by Associate
  • 572 Views
