missing-QuestionPost
Chip markings on the STSPIN32F0A
I recently purchased these from element14: https://in.element14.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10001&langId=91&urlRequestType=Base&partNumber=2797963&storeId=10186.The ones I got show this as the chip marking: https://i.imgur....
Drown higher current after read PRESS_OUT_XL (28h) value
We are using Nordic52 as a host controller. Hardware connected as shown below.Configuration as listed below:RES_CONF (1Ah): 0x00CTRL_REG1 (10h) : 0x02CTRL_REG2 (11h): 0x10As we observed that after read PRESS_OUT_XL (28h) register sensor drown higher ...
NPate.19 by Associate
  • 547 Views
  • 1 replies
Resolved! How to generate Flash ECC error ??
I wanted to test Error Correction code (ECC) for the flash memory (for both data flash and code flash) and was looking out for a way to generate these error. In the Reference manual (SPC560P40L3 micro), ECC Error Generation Register (EEGR) is given, ...
