will vl53l0x work in outdoors?
ANANTH
I performed all the calibrations indoor and whenever i am testing it in outdoor(both under direct sunlight and opposite) ,it is always detecting some particle without any interference.Do i need to perform calibrations again in outdoor?
John E KVAM
the crosstalk calibration is for how many photons hit your coverglass and bounce off. That does not change outdoors.
The offset calibration likewise does not change. It's accounting for a phase shift in the PLL that happened during re-flow.
So no, once calibrated you should be good.
Our community relies on fruitful exchanges and good quality content. You can thank and reward helpful and positive contributions by marking them as 'Accept as Solution'. When marking a solution, make sure it answers your original question or issue that you raised.
ST Employees that act as moderators have the right to accept the solution, judging by their expertise. This helps other community members identify useful discussions and refrain from raising the same question. If you notice any false behavior or abuse of the action, do not hesitate to 'Report Inappropriate Content'
1 REPLY 1
John E KVAM
