What should be the reason for getting a temperature value of 60 degrees?
2022-05-09 12:58 AM
Basically, I'm using the ISM330DLC sensor module and using the following example code "ism330dlc_read_data_polling.c" to read the temperature data. So while printing the variable "temperature_degC" I observed that the temperature was showing 60.
I went through the sensor datasheet where I found that the typical input vtg 1.8V was mentioned while in my case I'm giving 3.3V. So here my doubt is, will it affect the final temperature output value?
2022-05-09 12:59 AM
Maybe try to use Vdd=1.8 and see what happens?
if Vdd relation to vout is linear (1,8/3,3)*60=32ºC.... are you at 32ºC right now?
Also you migth want to calibrate it first ..
2022-05-09 12:59 AM
2022-05-28 04:47 AM
Thanks a lot, @Javier Muñoz by giving 1.8V from outside solved my issue.
2022-06-03 03:00 AM
